Talk to me about water pumps. We have a 2014 Wing River with a Shurflo 4008 water pump. The pump has given up the ghost. What water pump do you like as a replacement? We are looking for a quiet,effic...
I stuck with Sur Flo when mine died. Slight upgrade but not much.
NOTE: Some multi-switch Sur-Flo installs use a controller unit that is current limited. if you put in a pump that is too big. it can overload and burn out the controller.. Mine is a two switch (SPDT) and does not use a controller.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
