myredracer
Jan 26, 2018Explorer II
Using a suitable small wrench, disconnect the wire. Then you can simply tighten the nut that will squeeze the rubber plug some more. Reconnect wire - done! The sensors are just a rubber plug that gets tightened down after it's pushed through the hole in the tank wall.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
