myredracer
Jan 27, 2018Explorer II
If it's the polyethylene that is leaking, that is a much bigger issue. Maybe you could use a Uniseal slip fitting to block the existing fitting/opening by cutting a larger hole with a hole saw and inserting the fitting. Then drill a new hole for a sensor next to it. I think I've seen a similar mechanical type repair fitting somewhere but can't find it. The Tank Depot has them for $7. Harbor Freight has a plastic welding kit for $65 which some have used to repair RV tanks but may take some practice to apply the right amount of heat otherwise could still leak. Best thing would be a spin weld repair. You can buy the driver tool but is $200 plus you'll need a router to drive it. Icondirect has spin weld fittings and drivers here.
Probably best to go to a tank repair shop. But if it's under warranty, get it fixed by the dealer if it's the tank poly that is damaged.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
