That will be plenty I think. Pretty much all I will be doing is the TV and maybe charging two cell phones. I'm also getting the Westinghouse iGen1200 generator. It's a 1000 watt and 1200 watt peak. I'm guessing the max amp battery charger would be 8 amps this generator could handle. I would probably get a 5 amp battery charger and then run the generator 2 to 3 hours or less a day to top of the battery. Almost forgot the 650 watt coffee maker to make a cup or two a day. That shouldn't be to much at 600 watts for about 3 minutes a cup.
Jim
