Community Alumni's avatar
Community Alumni
May 22, 2019
Watts Help Needed.
I am trying to figure out how long a battery will last. I have Googled it and read a few sites but I still have a few questions.
I have a small TV that I plugged into my Kill a Watt meter. That shows 22 watts. I plan on using a 1000w inverter hooked to one 12v battery. I havn't purchased a battery yet so i'm not sure how many AH I will have to work with.
At 12v that would be 1.8 amps.
at 124v that would be .18 amps.
Which amp usage would I use, the 1.8 amps or .18 amps?
Thank You
Jim
  • Jim,
    I think DB levels are taken at a distance of 7 meters (22.9659 feet). I may be wrong about this.
    A larger generator with an eco switch may be more fuel efficient than a smaller one. It may also be quieter.
    When the time comes that you have an RV with a microwave the 1800 watt will power it--and the 1000 may not.
  • your charge WON'T USE 25 amps, it might charge at 25 amps at 14v = 310 watts
    25 amps 'use' times 120v would be 3000 watts
    amps will 'ALWAYS' taper down
    a charger doing 30amps at 14v will still taper to 1amp at 14v when the battery is near full
    battery capacity & ability to accept the charge determines the amps at 'ANY' voltage
    a partially used battery has a lower internal resistance than a charged battery
    as the battery charges, the resistance to accept charge also increases
    the battery controls the amount of charge it accepts, not the charger
    automatic 'car' battery chargers, turn OFF, when the battery acceptance slows down
    they shut off before the battery is fully charged
    i know this is a lot to learn,
    BUT learning to understand the 'terms' correctly, and correctly charging your battery, will save you money and future problems and expenses
  • Nice post Mr Wizard.
    310 watts / 0.7 power factor gives about 443 watts.
