wa8yxm wrote:
Ok re-charging rates.. Recommendations vary from both battery manufacturer to manufacturer and from Others as well
Xantrex for exmple recommended 30% C/20 as the peak
Trojan 10%
Lifeline originally 30% as the MINIMUM initial current later reduced to 20%
(That is only for their AGM batteries)
Generally speaking the lower the recharge rate (Down to a point) the longer the overall life of the battery.  I suspect that point is Trojan's 10%
I ran around 550 AH of batteries with 80 amps peak for 9 years.
ya, and to get around the worry of to much, you could also use tempature compensated solar charger.  I have this set up alredy, just have to add another pannel before I need it yet.
Steve
