Update - the Forest River regional rep just called me. Despite being out of warranty, they are going to cover everything in good will. They advised me to take it to my dealer and they will cover a new controller (either an R LUX, or a Go Power) as well as a new chassis battery. This is my second FR Rv (previously a Cedar Creek FW) and I have to say I have been really pleased with their customer support. I've owned a few other brands and most are usually a PITA to get them to cover anything in warranty let alone out of warranty. Happy customer! Thanks for all the replies on this one.
That’s great to hear. IMO they are only fixing half your problems.
solar controller crapped out. No big deal. Easy replacement.
battery dead. Great they are replacing it but first it “should” have lasted longer if it’s actually a bad battery. But entirely possible it’s just a defective battery that won’t charge.
However you suspect a parasitic draw and that literally takes 2 min to diagnose.
If that the case, that is the most important thing the dealer needs to fix. And assuming you better get it now while they’re being generous about goodwill warranty. A battery and cheap charge controller are just parts replacing.
I’d diagnose the presence of a draw before even taking it in, so you can be confident in what they need to fix.
No, it shouldn’t go dead in 2 weeks. Or 2 months. Maintainer shouldn’t be mandatory for a couple months in nice weather.
- way2rollOct 27, 2024Trailblazer
Personally, I think the chassis battery is fine. Takes and holds a charge fine. It just went dead sitting 2 weeks in storage. I think Mercedes nature of the beast with all the electronics. It was enough charge to start it but barely. I've had similar experiences with an e350 and c300 I previously owned, and a bmw when they sit for 2 weeks. Heck, my 37 year old jeep does it too.
- Grit_dogOct 28, 2024Trailblazer
PS it’s super easy to diagnose whether there is a draw or not. Most simple is unhook the battery and wait and if it starts when it wouldn’t have if hooked up, it’s not the battery.
more accurate way is just check with an ammeter in line between the neg battery post and the neg cable (ground). Any more than a handful of micro amps and it’s a problem. - Grit_dogOct 28, 2024Trailblazer
Personally I know you’re intentionally overlooking an issue you don’t want to deal with apparently.
My suggestion was to get it handled while you may not have to deal with it (financially), although the vehicle warranty is still in tact (you said 2023 model iirc), so I guess you could take it to Mercedes later or just keep masking the problem with a battery maintainer.
I assume by “chassis” battery you mean the starting battery not the house battery.
For the record, it’s not “normal” for any vehicle to discharge rapidly when not operated. Including old jeeps. 50 year old CJ here that I haven’t disconnected the battery cables in years and it rarely gets driven. Sits for months at a time and if I remember or are feeling generous with my electrons I might throw a maintainer on it once in mid winter if I’m walking past it and it looks sad…Now can’t speak much to German engineering. But can say that a 40 year old VW was an electrical pos 30 years ago. And the one BMW I rented a few years ago had more electrical problems in a week than all of the dozens of other vehicles I’ve owned or driven for 30 years.
Doesn’t mean it “should” be a problem though. I don’t know anyone who pays 6 figures for a vehicle and then accepts it having a fatal flaw like an uncontrollable power draw.- way2rollOct 28, 2024Trailblazer
Appreciate the concern, I'll ignore the incorrect assumptions. I'll have them test it at the RV dealership as well as when I take it into Mercedes next month for it's service. Could be a defective battery - or a small draw even with disconnects. I remember when I first got this MH, very cold start one morning and it ran like my old Kubota used to until it warmed up in sub zero temps. And a few times since, when in storage for a few weeks it ran rough for a few minutes even in warm temps. Considered it more of a diesel problem than a battery problem. Frankly I don't really care for the Sprinter Chassis. It rides nice, but it's a little anemic on power when towing and does some weird electrical stuff periodically - alerts for no reason while driving etc. .
- StirCrazyOct 28, 2024Moderator
heck my 2014 f35 can sit for 2 months and be good. does that every winter. 🙄
