tkcas01's avatar
tkcas01
Weird Solution to Weird Laptop Issue - disappearing popups
One of the features I like about the RV.net forums is that I can hover over a post and see a pop-up box with a preview of the post. Recently on my Dell 1530 laptop those would only "flash" on the screen for a fraction of a second.
Same issue was also affecting the pop-up preview windows when I would hover over an open program minimized on my toolbar. As a result I could not get back into the program. Even Alt-Tab would not work to cycle through open programs.
Based on discussions in various forums, I started trying things to fix it - turned off the sidebar and gadgets, reinstalled mouse drivers - nothing would work, not even after rebooting.
I then found what ended up being the solution and I am still flabbergasted that it actually worked. How in the world someone figured that out I have no idea. The solution:
  1. Shut down the laptop
  2. Disconnect power
  3. Remove the battery
  4. Press the power button and hold for a few seconds.
  5. Replace battery, AC power and boot up.
When it rebooted, the problem was solved. The other weirdness that was happening, and maybe a symptom of the same problem is that when I would boot it, it would beep rapidly about a dozen times, then display a text screen asking me to select which operating system to boot - there was only one, Windows 7. When I would select that it would beep rapidly another dozen or so times, then proceed to boot.
After following the steps above, it also stopped doing that. It is almost like there was some strange electrical gremlin in there and following these steps removed the electrical charge. Like I said - Weird! Thought I would post in case it might help someone else.
  • The remove all power solution is used when the system loses its BIOS due to a bad chipset on the motherboard. I hope that isn't your problem.
  • I have used the "remove the battery" fix several times with cell phones and other electronic items. It seems that not everything is wiped clean unless ALL power is removed.
    I have also learned to remove the battery from my laptop if it won't be used for a few weeks. If I leave the battery in the laptop, it will be discharged the next time I boot up. But if I take it out, it will still be nearly fully charged the next time I put it back in the laptop. I can only conclude that the laptop still draws some small amount of power after being shut down.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    It may be browser specific but I do recall seeing a configuration item in a settings menu (or in the browser Chrome file, not to be confused with the chrome browser) that had to do with how long those pop ups remain visible.
    What I forget: Is where I saw the blasted setting.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 20, 2026
