MEXICOWANDERER's avatar
Aug 22, 2020
Wet and dry bulb comfort measurements
https://en.m.wikipedia.org/wiki/Wet-bulb_temperature
Wet bulb, dry bulb comfort measurement.
Wrap the wet bulb thermometer with cheesecloth.
Blow a fan across the bulb.
This is the lowest temperature that evaporative cooling can achieve at that point in time. A very useful tool.
https://www.ebay.com/itm/Economy-Sling-Psychrometer-Kit-Containing-1-Dry-Bulb-and-1-Wet-Bulb-Thermometer/272039610505?hash=item3f56d30889:g:gEAAAOSwf4ldVxI0
  • No batteries no transistors no drift no plus minus percentage errors. And twelve dollars.
  • wa8yxm wrote:
    One way. in fact the most accurate way. to measure humidity requires a dual bulb (one wet one dry) thermometer a piece of string and a book.
    You start by slinging the thing around for a bit.
    Read both thermometers and note the temps
    Look the dry temp up in the book then the wet and where the two cross
    HUMIDITY.
    Just get a sling psychrometer, (Amazon} I used them at work to determine the wet bulb temp. That's what the 'Feels Like' temp comes from. It's done electronically now, my indoor-outdoor thermometer does it with no slinging. This old tech....heh.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    HUMIDITY.
  • Only way I survived summers at Ft. Irwin was to keep my uniform wet. Didn’t know the science...did know the relief.
  • So true. 28 1/2 years Aeographers Mate. It gets trickey when temp gets below freezing.
Having RV issues? Connect with others who have been in your shoes.24,235 PostsLatest Activity: Apr 10, 2025
