Old-Biscuit wrote:
Slide rides up and over floor when retracted.
Bottom edge of slide out needs to 'seal' against frame of trailer when retracted.
Tires throw water UP when driving in rain. Rain gets in thru bottom edge of slide out if seal is missing/out of position/damaged
Open slide out.crawl underneath and inspect seal/sealing area.
Have someone close slide out while underneath and check how it seals up.
Yup. yup. I did all of that. I did find a lot of dirt on the seal at the bottom and cleaned it real good. It was a lot of grit and sand. Now, I have to travel on a rainy day to see if it still leaks!
