tenbear
Jul 07, 2015Explorer
joebedford wrote:
My rig has a WFCO 68100 converter - 100amps. PD maxes out at 80amps.
If I put in an 80amp converter, I assume that in the rare case that I'm drawing 100amps the converter won't keep up and the batteries will discharge.
Would that damage anything? Like will the converter "blow a gasket" or something?
If the battery wants to draw 100A, the PD XX80 will simply limit the charging current to 80A until the battery is sufficiently charged to accept less current. The battery will not be discharged, only be charged at a slightly slower rate.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
