tpi
Jul 08, 2015Explorer
Question about PD w/ wizard: Short time I've used it observed voltage output seems to be based on a time schedule only (not touching wizard). 14.4 volts for x number of hours, 13.6 for x number of hours, then 13.2 after that. Batteries can be floating along drawing less than an amp from solar at 14.4 volts, start converter and 14.4 volts for the usual x number of hours from converter (solar off)-then the rest of sequence. I'm perfectly fine with this for my purposes-no complaints. Is this typical observation for these converters?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
