tenbear
Jul 08, 2015Explorer
tpi wrote:
Question about PD w/ wizard: Short time I've used it observed voltage output seems to be based on a time schedule only (not touching wizard). 14.4 volts for x number of hours, 13.6 for x number of hours, then 13.2 after that. Batteries can be floating along drawing less than an amp from solar at 14.4 volts, start converter and 14.4 volts for the usual x number of hours from converter (solar off)-then the rest of sequence. I'm perfectly fine with this for my purposes-no complaints. Is this typical observation for these converters?
Today I turned on my PD9260 and it started charging my fully charged battery at 13.6v, not 14.4v. The battery voltage between chargers read over 13v, surface charge.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
