time2roll
Oct 10, 2017Nomad
lawrosa wrote:Depends on the rating but no PD-55 will be sagging to 20 amps if the batteries need the charge. WFCO at 13.6 will taper off the charge faster every time. Once in absorption mode it is not about the converter but the voltage and the battery. If the same rated WFCO puts out more amps it will only be for a few minutes.
But is it true say the wfco charging at 30 amps 13.6 vs the PD at 14.4 20 amps ( lower volts = more amps) it would be a wash?
