time2roll
Oct 11, 2017Nomad
lawrosa wrote:Your WFCO is never in boost.
Its clearly dropping out of 14.4 constant current mode at some point... but when?
There is no constant current mode. There is a maximum current and a maximum voltage. The battery determines the rest.
When you start charging, the voltage at the WFCO is above 13.2 volts so you will never see boost mode. You may still see max amps for a short time at 13.6 volts. Then it just tapers off to a trickle charge.
