lawrosa
Oct 11, 2017Explorer
I assume this is the recommended converter?
http://www.bestconverter.com/PD4655MBA-WildKat-55-Amp-Main-Board-Assembly-for-WFCO-8955-or-Parallax-7155-Includes-4600-Remote_p_616.html#.Wd6K-WhSyUk
Im draining batts down now and added a wire parrelel to the existing.
Its #8 wire. In preliminary testing I get more amps through the #8 then the #6. I believe thats because there is a 40 amp breaker inline on the #6 and it adds resistance...
Ill let you know if I get a bulk of 14.4 readings anywhere. Ill test for two hours or so.
Question..
If its in bulk mode, how will I know?
Lower amps more constant?
Should I see 14.4 at the converters charge wires?
How will I know when it drops out of bulk mode? ( if it even goes in..)ie: will the amps gor from say 24 amps to 30 amps when it changes to 13.6?
Question..
