BFL13
Oct 11, 2017Explorer II
No, you are down to 9 amps still in "Boost" You are also down there in "Absorption" (amps tapering), (Sigh!) You are not in "Bulk" you are in "Absorption", but the converter is still at its "Boost" voltage of 14.4 (Sigh!)
If it does not get down enough in amps to trigger its drop to 13.6 after four hours and it does drop, you have to reset by unplugging its 120v (wait a minute to let the caps drain) and start over for another four hour run--but that run will no doubt end before second four hours as the amps get down enough to trigger the drop to 13.6.
