lawrosa
Oct 16, 2017Explorer
red31 wrote:
got a link to that 20%? Trojan says 10-13% and can go to 20%, when asked they claim no limit but $$$$ and temp.
"Below is Trojan Battery's response:
There is really no limit to how high the initial charge current can be. We recommend that range of charge currents because charge systems are usually power limited and so we have to give customers a range. There are two things that you have to watch for when using high currents to charge batteries. The first one is that the current must be lowered before the batteries reach a voltage of 2.35 volts-per-cell. The second one is that the battery does not exceed 114°F. The only real advantage of having high charge currents is shorter charge times, but the implementation costs are usually too high.
Yes flooded max current here for deka batts... ( AKA duracells from sams club)
Also max time 1.2 times AH/ avg current.......
I float mine at 13.8 on solar....
http://www.eastpennmanufacturing.com/wp-content/uploads/Renewable-Energy-Charging-Parameters-1913.pdf
