96Tony
May 06, 2014Explorer
WFCO converter & battery questions
Okay, my '14 Premier Bullet 19FBPR came with this WFCO Power Converter w/ Distribution Panel.
It's a 3-stage charger which (I gather from all my research) is good.
http://www.wfcoelectronics.com/UI/Power-Centers-WF-8955-55-Amp-Power-Center.aspx?ptype=3&pid=9
Here are the specs on the tag;
Panel Input.........120Vac 60Hz, 30A
Converter Input.....105-130Vac 60Hz, 12A, 950W
Converter Output....13.6VDC, 55A
And here are the outputs from the manual;
Absorbtion Mode: 13.6Vdc
Bulk Mode: 14.4Vdc
Float Mode: 13.2Vdc
I'm planning on adding another 12 volt true deep cycle battery, to supplement the stock group 24 marine deep cycle battery. Also, a 1/2/Both/Off battery disconnect switch, making it easier to monitor off-gas state-of-charge make it easier to dry camp for extended periods of time. (Although I wouldn't run two different batteries at the same time, right?)
I considered solar, but feared the output would not re-energize a battery in a primarily shady location.
Plus, I cannot find a local expert to help my plan a small solar system.
So, I think I'm just going to spring for a Honda EU1000 generator, and reluctantly run it every 2-4 days. With very light electrical use (fridge controller, LP detector, infrequent water pump, occasional LED lights), does that sound about right?
About how long would this small Honda have to run to bring a group 24 stock marine deep cycle from 50% back up to 90%?
Would a better-quality true deep cycle take longer?
I would direct connect it to the trailer's charger described above, right?
Thanks in advance for any answers, thoughts or suggestions!
Bulk Mode: 14.4Vdc
Float Mode: 13.2Vdc
