- +1 MEX
- MEXICOWANDERERExplorer"From the brochure
Well-maintained
batteries should never need more
than two-stage (Normal and Trickle)
charging. "
This is absolutely succinct. An admission of stupidity from a battery charger manufacturer who declares the word "Boon-Dock" to not be in their dictionary. To them, Power Pedestal Princess is on their mast head
If they do not recognize the word they certainly haven't a clue as to how to go about engineering a device to charge batteries. Read their brochure comment again. - scrubjaysnestExplorerOnly way to tell is test it.
- red31Explorerfrom the brochure
Well-maintained
charging. Our third stage (Bulk)
is provided for the rare times a
battery needs extra-power for
charging. See wfcoelectronics.com
for details
this means a very deep discharged battery may induce 14.4v
http://wfcoelectronics.com/wp-content/uploads/2015/11/WFCO_60_9800_CONVERTER_03.pdf - MrWizardModeratorI had a wfco 98100, that I installed
And yes it would goto 14.4v bulk mode
The battery charge wiring is "1 aught"
Came that way from the factory, with the OEM installed Freedom 10, 1000w inverter, 50 amp charger
Which I had to replace after burning up the pass thru circuit
(My fault) - Daddy_BearExplorerNow that's ironic! I am sitting here reading the owners manuel for the WF 9800 series converters. Our new TH has a WF9875 (75 amps). The manuel says it has three modes...on of which is 14.4.
Interested in seeing others opinions for this as well.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
