BobKrogstie wrote:
bpounds wrote:
I think you would be okay either way.
But, where did you get the 20A info? Because I see a draw of 1300W on the input, which would only be 11.x amps. No where near needing a 20A breaker.
Link to a good source:
PD 9280
Here under Specifications: Link to Specs
Hmmm, I see. I think that converter comes with a power cord and plug, so they may equip it with a 20A male plug. That would be the type with one blade perpendicular to the other. I don't know why they would do that for a 1300W load.
I would be tempted to buy that, and simply replace the plug. But first I would confirm that the max load is really 1300w, and if it is, no way does it need a 20A source. If you want the simple path, just go with the 70A version. I don't think you will see any problem with performance. It will still be better than what you are replacing.
