rhagfo wrote:
otrfun wrote:
BobKrogstie wrote:
bpounds wrote:
I think you would be okay either way.
But, where did you get the 20A info? Because I see a draw of 1300W on the input, which would only be 11.x amps. No where near needing a 20A breaker.
Link to a good source:
PD 9280
Here under Specifications: Link to Specs
The WF-9875 in our toy hauler was connected to a dedicated 20 amp breaker, which I believe is what WFCO recommends for the WF-9875. Unless you want to use a 15 amp breaker with the PD9280 (against PD's recommendation), I'd say you have no choice but to go with the PD9270 (or smaller).
According to the WFCO WF-9875 installation manual the WF-9875 draws 15.7 amps under maximum load. Slightly more than 15 amps.
:h
Change the breaker to 20 amp, and the outlet to a 20 amp configuration, maybe $15 worth of the parts.
If the existing wiring will support that amperage (run length and gauge) could be a viable option. However, without knowing the OP's run length and gauge I wouldn't feel comfortable recommending this.
