bpounds wrote:
rhagfo wrote:
:h
Change the breaker to 20 amp, and the outlet to a 20 amp configuration, maybe $15 worth of the parts.
Not knowing the size of the wiring in the trailer, I would never recommend changing the breaker.
Change the outlet, okay. Change the plug on the cord, okay. Because it is still protected by the original breaker.
Moot point though, since the PO has already made a wise decision.
Well on my center the outlet for the converter is part of power center, a simple pigtail single outlet unit complete with correctly sized wire. I doubt many are on a separate wall outlet, but in that case yes 12 gauge wire.
