MEXICOWANDERER
Aug 11, 2015Explorer
Single conductor 26-gauge wire does not make it a cable. A 24 gauge stripper does not strip the wire and a 26 gauge telecom stripper does not nick the conductor when stripping. I've got 3-1/2 digit gauges that increment .4 volt up or down. So they can be classed as .8 volts + -
One of the best of the gauges is an LCD meter called a VOLT MINDER. It is a low voltage alarm that someone here on this forum clued me into several years ago. Three and a half digit impressive sampling rate and it has endured a lot of use. It is linear inaccurate but liveable with a .07 error @ 14.00 volts. Of course the meter is no longer available :(
The new to me 4.5 digit volt meter is accurate. Only time will tell if it remains accurate.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
