Sea_scape
Jul 27, 2013Explorer
Reading the Ebay description, I believe that you would need to install an external shunt to measure the current drain from a battery. It will measure current directly, but if you look at the terminals, you can see that they are rated for 20 A, which is about #10 wire. Good for measuring one circuit only.
I can understand the calculation for watts, but Ahrs I'm not on sure. It would need a clock and cumulative storage. I'm guessing Ahrs is just A times something to give an instantaneous value that suggests what it would be if the current was steady for an hour.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
