wolfe10
Mar 14, 2015Explorer
Fuses are sized to protect the WIRE, so the wire gauge will determine the correct fuse.
It will be in the range of 10-30 amp depending on wire gauge It will be in the line from isolator (right at the isolator)to the camper.
Be sure to run a comparable gauge ground/negative wire from camper to truck frame.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
