csamayfield55x
May 10, 2016Explorer
I can almost guaranty they won't work the first time you hit them! If mine sit for a long time I will manually drag the brakes a few times while doing about 25mph to blow the dust out. If after that you don't have the braking you want it might be time to adjust. I would be a bit concerened about bearings sitting that long in the same spot too. I would check them often on the first few hundred miles to see if they are getting hot or loose
Chris
Chris
