- Ron3rdExplorer III
bcircus wrote:
Thanks everyone for all the suggestions and ID of model. If I have to replace it can it be done from top with removing toilet. Can I get the repair kit on line?
Yes, all available online.
You might want to try what I posted above first, your seal might be fine, just full of sediment or other crud. - bcircusExplorerThanks everyone for all the suggestions and ID of model. If I have to replace it can it be done from top with removing toilet. Can I get the repair kit on line?
- Ron3rdExplorer IIIThetford has a procedure to give the seal a "tune up" without actually replacing it. You add hot water to the bowl after removing and cleaning the seal, and let the hot water sit in the bowl for a while. You also want to lube the seal after putting it back in. I had the same problem with my 1 year old toilet and this fixed the problem. Did not have to replace the seal.
- edatlantaExplorer IIThetford Aqua MagicĀ® Style II
- bcircusExplorer
toilet in my 2011 Montana. can anyone ID the brand and model. China/Porc bowl - BB_TXNomadDid you try looking down and behind and near the bottom of the base on the side opposite the flush pedal? I think mine had a label there with manufacturer and model.
Also as a new Montana owner, go over and join the Montana Owners Club forum for all things Montana. - TucsonJimExplorer IIIf you can post a picture, it might make identification a little easier. Use this link to enable posting your picture:
RV.net photo posting tool - 2oldmanExplorer IIpost pic. We'll tell you. Some units have many owner's manuals covering each item.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
