olygene's avatar
olygene
What do these two nuts do?
While cleaning out a storage bin, I noticed two nuts protruding down into the bin on a 2005 Lexington 255. One is rusty and the other looks to be stainless. The stainless has a pin through it. I think one is to manually retract the slide but I am not sure which one. If it is the stainless nut, do I have to remove the pin first before turning the nut?
My RV friend thinks the rusty nut is to vertically adjust the slide but the nut is very loose on the bolt; if he is right, does the nut have to be tightened for it to work properly or shall I leave it loose? Thanks for any input.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
