hbillsmith
May 02, 2017Explorer
Dennis12 wrote:
My 3000 Honda will run anything I need to run. May have to shut it down if i run the hot water tank on electric, but normally use gas. The nice thing is I don't have people around me discussed with the noise like the Champions put out.
I assume you're talking about Champion Generators not Champion Inverters. At 58db my Champion Inverter is about the same as my neighbors Honda. But if you mean the open-frame type construction Generators, you are correct sir, they can hit decibels in the high 60's.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
