time2roll
Feb 11, 2016Nomad
50a changes a bit. Now you get to look out for 120v vs split phase 120/240v service. Larger generators tend to be 120/240 volt output. So with 120/240 you really need 3000w per side or 6000 watts. If you go smaller (4000w?) make sure is has full wattage at 120 volts so you can use an adapter to feed both sides.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
