JiminDenver
Feb 11, 2016Explorer II
With the solar, batteries and inverter I am converting our bunk house to run off electric as much as we can. We cook, make coffee, heat water, use a A/C and I am working on the fridge. We even use a small 200 watt heater in the bathroom to take the chill off early instead of running the furnace.
So except for heat I don't see why you couldn't do the same by replacing the solar with a generator. Run the generator for the big loads and charging, batteries and a inverter the rest of the time. I worked out having A/C on solar in a limited fashion, that was said to be impossible. Someone else will have to work out having electric heat.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
