- swimmer_speExplorer
2112 wrote:
My gray tank is full when the shower no longer drains.
My black tank is full when the toilet burps when I flush.
My gray fills up long before the black. I put a valve on the main drain pipe where you connect the drain hose. With that valve closed I open the gray valve, wait a few second, then open the black valve to move some gray water to the black tank. Then close both valves. That gets me at least another shower before to the dump we go.
Do you have a picture of that setup?
Both of mine go to one main drain with drain valves for both tanks. - wnjjExplorer II
You can do this trick by just leaving the cap on the end but you will have to deal with the “extras” when you pull the cap to connect the hose at the dump. - swimmer_speExplorer
Sounds nasty. Best left for times of desperation. - wnjjExplorer IIActually there is this add-on valve you can use. Then once your tanks are empty you can always remove it.
DO NOT TRY THIS WITH JUST THE CAP IN PLACE!!!
People really should think before they post this stuff. If you want to use this method get yourself one of the twist on valves for the end of your drain line. That way you can attach the hose before you let the c r a p fly.- swimmer_speExplorer
That valve looks better than just letting it fly... - LantleyNomadAll you need is a twist on drain valve. Permanently attached it and get rid of drain cap altogether.
With valve closed and both tanks open tanks will equalize and you can allow black tank to fill with some excess grey water - Cummins12V98Explorer III
ken56 wrote:
If your black tank has a tank flush on it, if you leave that run by mistake yes, it will overfill and will come out the vent pipe on the roof. All tanks have a vent of some type so they will drain. Be very careful you are not distracted when you use the black tank flush and forget to shut it off.
I ALWAYS SET THE TIMER on my phone!!!!!!!!!!!
Distracted dumping can end up being a real SH!TTY experience. :B - Grit_dogNavigatorOr short story is, if you overfull the black tank you have to be pretty dang unobservant, short of a toilet valve and flapper leak at the same time.
And if the gray gets full unexpectedly, unless you’re sardine camping, u can always water the lawn late at night…. - wnjjExplorer II
Thanks for the warning but it should be obvious I was “thinking” about it. This is why I suggested there would be extras to deal with. It’s just gray water left in there and won’t instantly kill you either. Many dump stations have a sloped pit that runs to the drain so it’s easy enough to deal with. I’ve known a couple different people who had use this method in a pinch. It’s not like you can “just install a valve” when you already are at a camp spot, late at night and your family cannot use the sink. Relax a little.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
