Ron_Nielson
Jan 24, 2014Explorer
BFL13 wrote:
Could the emergency breakaway pin be pulled and those amps not show on the tester where you measured from? That would not show when pulling each fuse. It would show when he tries to pull the trailer next time I suppose!
Powered tongue jack on?
The parasitic load test was done at the battery and should have picked up the situation you outlined. Good thought. He had another circuit outside the circuits thru the converter/charger. It had been disconnected at the time we were working on it.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
