- BobboExplorer II
mat60 wrote:
Roof is done for now but Im not sure if the Proflex will stick to the Silicon if that's what it is. I guess I will find out.
That is the problem with silicone. It works great, but if you ever have to re-do it, you are in a world of hurt. Nothing sticks to silicone, even more silicone. - NRALIFRExplorerI like OSI Quad around the house and on the RV.
I’ll share a tip with you on preserving open tubes of caulk as well. Some caulks keep quite well after opening with just a rubber cap on them. Others will harden up once opened even with a cap. I have a bunch of these plastic bottles available that I use for various things. I cut the neck off, leaving a hole that the caulk tube fits in snugly. If the caulk is water cleanup, I put a couple inches of water in the bottle and turn the open tube of caulk upside down in it. If it’s a solvent cleanup type, like OSI Quad, I put a few ounces of mineral spirits in the bottle.
A couple of these tubes have been opened for over a year, and they are still useable.
:):) - T18skyguyExplorerOne thing I recently learned is that caulking has an expiration date. I did a real nice caulking job around a tub, and it never dried. I did it over with a new tube no problem.
A caulking called " Through the Roof" is excellent and will never crack, but I don't know if it's ok for RV's. GE Climeaclear is a good one for RV's so I've been told. - MURPHY55347ExplorerWinnebago calls out Stone Mason gutter and siding caulk for all exterior body seams. It is not used on the roof. Stays pliable but does not attract dirt. Only place I have found this is direct from Winnebago. Appears to be only sold in Canada now. A substitute is Nuflex 640 or Hengs 96600. Hengs has bought out Nuflex. Roof call out if for Nuflex 311.
- Dennis12ExplorerSika
Sikaflex-221 White 10.1 fl. oz. Cartridge
Comes in different colors.
I have been in the construction industry for over 40 years. I have used many of the Sika products that are state and federally approved and without a doubt it is the best product on the market. Amazon is selling it. - mike-sExplorerSikaflex 221. I tried Geocel Proflex RV last year - it's harder to work with and stays sticky for a long time, attracting dirt.
For opened tubes - push a golf tee into the open end, then cover that with some plastic wrap held on with a rubber band wrapped around. Works great. - HadEnoughExplorer
SidecarFlip wrote:
HadEnough wrote:
Depends on the job you are doing and if you need to easily remove hardware later, etc.
Nothing wrong with silicone for glazing purposes.
Usually use 3m products in general.
I agree. Silicone has it's place even in the RV world. I use Sikaflex products myself.
That's some quality stuff. I use that in the marine world. - SpridleExplorerI like Sikaflex 1a as my favorite no-sag calk.
- RLS7201Explorer II
dougrainer wrote:
I use DAP Adhesive Caulk and have for over 10 years. There are 3 versions DAP makes. 1. Comes out white(so you can make sure you have filled the area gap) and dries crystal clear. SO CLEAR, that I have had customers complain I did NOT seal the areas I sealed and I had to poke it with a pen to show them it is sealed. 2. CLEAR 3. WHITE.
This is an ADHESIVE CAULK and will adhere to almost anything except a EPDM/TPO roof which you would not use this product on the roof anyway. I use it to bond wood panels inside the RV and other things that need a ADHESIVE. It bonds to the Plastic/fiberglass shower walls and will bond to Glass. I have not used Silicone sealant since I found this DAP product. Doug
PS, It does NOT flow like silicone, it is smoother and not as lumpy as silicone.
https://www.zoro.com/dap-adhesive-caulk-101-oz-clear-18242/i/G4531247/feature-product?gclid=EAIaIQobChMI2Nmk-cWP3AIV3rXACh2qZAS6EAQYAiABEgJBLvD_BwE&gclsrc=aw.ds
X2
I'm with Doug on this one. I also use DAP on anything but EPDM.
For EPDM I like Sikaflex 221. Never had it crack.
Richard - 72cougarxr7ExplorerThanks for the suggestions everyone!
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
