eHoefler
Jul 22, 2018Explorer II
I lost a set of brakes in less than a year, linings let loose and came off. For the what they want to do your brake job, is way over priced. Parts will run you $150-$175 per wheel at most, that is a complete backing plate and new hub assembly. If you shop around, you can get the parts for about $125 per wheel, that is what I spent for 7,000 pound axles.
For the money they want, you could easily have disc brakes installed. When my drum brakes went the second time,in less than a year and 5,000 miles, I went disc. The kit cost me $1600 at my door. I spent 6.5 hours installing, I'm a former line mechanic for KW. Should of done the conversion sooner, there is no comparison.
