fj12ryder
Jul 26, 2018Explorer III
CarnationSailor wrote:Well, if they're trying to get that past you it would make you wonder how much other stuff they also made up. Total BS.
myredracer:
LS said it was prudent to replace the bearings with the hubs because the old bearings and the old hubs would have had mating wear grooves, and that the new hub would have none; hence, the old bearings wouldn't fit well with a non-grooved hub. Anybody know if this is true?
Wheel bearings have an outer and an inner race, the rollers turn against those surfaces. The hub only holds the outer race in place.
