fj12ryder
Jul 26, 2018Explorer III
They may have been referring to replacing both races of the bearing at the same time, not just the one on the axle or the one in the hub. You do want to replace both races at the same time.
Tapered roller bearings, should be replaced as a set: inner race, outer race, and roller assembly. Whether you choose to replace the drum at the same time is totally dependent on you.
