ScottG
Aug 08, 2014Nomad
BFL13 wrote:ScottG wrote:
Yep, you have a grey tank just for your kitchen sink - a nice feature as long as it doesn't have a separate drain.
Must be complicated in a slide-in camper sized rig, with the galley tank quite small. Our 5er has a galley tank that is half the size of the other tanks, so it always fills first unless we take steps. An even smaller tank would be even more annoying.
Taking those steps is a PITA (wash dishes in a sink insert, dump the insert into one of the other tanks eg), but yes must be even worse with rigs that have two sani dump terminals.
Some people do some plumbing to get around that so the two grey tanks share. It depends on your camping lifestyle which tank fills first and what you are willing to do about it.
BTW the galley tank monitor is likely to give false readings of being more full than it is, due to food etc getting on the sensors. You can get a true reading from when the water won't go down the sink drain anymore :) If it is a PITA do dump that tank when the others don't need it, ignore the monitor until the sink backs up so you don't do extra work not needed yet.
Yes, our drain is plumbed into the one sewer hose connection. To have separate SH connections would be a pain.
We never fill our galley tank. It's 20 gallons and the other grey is 40 so that kind of give us a total of 60 which has served us well.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
