Salvo
Nov 01, 2014Explorer
That's an oh **** add-on. The step controller has problems with over voltage. There should also be a zener diode in the wiring harness where you found the resistor. The resistor/zener combo prevent over voltage. It's a kluge fix. Over time the lead to the resistor will break, resulting in your steps not working. Replace the resistor and you'll be good for another 6 years. You could add some strain relief to the resistor/leads.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
