Salvo
Nov 01, 2014Explorer
I wouldn't try to put a few 1/4W or smaller size wattage resistor together to get your 1.2k ohm. The smaller the wattage the thinner the resistor lead and therefor the quicker it will break. If anything, go with a larger wattage resistor. The 1W resistor from ebay looks good.
I believe the resistor/zener harness is from Winnebago. I had the same issue about 4 years ago. I think the zener is around 18V. It's meant to clip voltage spikes; perhaps from a noisy alternator. I don't think it's anything real critical. The steps should work fine with this harness removed. Order the resistor from somewhere and solder it in. It's not complicated. You can do it!
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
