tbiker99's avatar
tbiker99
What is this valve for?
Any idea what this valve is for? I bought this camper used and the previous owner didn't know what it was for either. Nothing comes out when it's open. I don't know if it is a vent for a tank or a drain for the A/C, but I can't see why I'd want the ability to close either of those.
2011 Big Country 3494QBS
  • Have you had it open when running water pump or with city water connected.
    Looks like it has a 'barb' fitting so think it had some other hose connected.maybe for spraying down with ???
    Fresh water tank DRAIN???
    Inside RV directly above where hose goes thru-----what is in that area?
    A/C Unit drains are just small holes in drip pan and condensation run down roof line and off trailer
  • Suction inlet for winterizing? LP gas hookup for portable grill (or inlet for connection to a larger bulk LP tank)?
    I doubt it's an air suspension setup, both because those typically have a tire valve sort of arrangement and because I don't think air suspensions are at all common on fifth wheel RVs.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
