jrat's avatar
jrat
What is this wire???
Hello all. I have a parallax converter in my trailer and have a question. I understand the black and red wire coming from the battery. On the same lug as the black wire is a smaller white wire. What is that from? Also, between the red and black lugs is a blue wire labelled only as VCC. The manual doesn't identify this wire. What is it? I ask because I was poking around checking my fuses and noticed the first inch of this blue wire was charred like it heated up too much. My 12V system works fine. My 120 all works when on shore power or geny. The only potential issue is my batteries don't seem to charge well if on shore power. Does this wire charge the batteries? I trimmed and redid the blue wire and have seen no further issue. I unhooked at the battery and while on a geny was getting 3.08 volts between the positive and negative battery cables. Is that too low? thanks,
