jrat wrote:
OK - the two 30 amp fuses are fine. The blue wire was singed so i trimmed it back and reattached it. How can I test to see if the panel is working? My rig runs fine off the battery bank. Should I disconnect batteries and plug in to shore power and test across the blue and white wire? That should ready 13.8? Is that right?
Correct. Don't use the battery disconnect switch, take the neg or pos wires right off the battery post so you have no battery at all.
Plug in to shore power or generator so you have 120v. You should have 13.8v approx. at the battery lugs on the fuse panel.
If not, (zero volts or whatever) then go back and recheck your blue wire repair, since the last thing that got fiddled with is usually the first suspect :)
BTW that burnt blue wire may have come in contact with the white ground at some point--and note that the entire metal box all that comes in is a "live" ground so it can touch almost anywhere for that to happen.
