Tachdriver
Apr 06, 2014Explorer
Did your TT come with a pull-out cord or a detachable? If it was detachable was it not included?
As mentioned before if you are going to run the AC or multiple appliances I would recommend staying with your 30A cord, not just an extension cord unless you are going to keep the batteries juiced up.
I had a pull out cord but converted it to a detachable mainly for the reason that the connection between the outside cord and the house wiring to the power panel was inside of a metal junction box. The neutral wire nut came off and shorted to the box and ground. I made a temporary repair and bought a conversion kit which now I can safely sleep at night.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
