- GjacExplorer IIIThe one lb canister gives you the flexibility to use the stove at the table in your campsite instead of being tethered to the RV by a hose. If cost is an issue the canisters can be refilled from a larger tank. I had this same issue with my Buddy heater being attached to the main tank via a hose, but my wife liked it in the bathroom when showering and getting dressed and then in the living area afterwards I did not want to have a 20 ft hose.
- AlmotExplorer IIIIf it's just a stove, not a grill - it will last a few days on 1 lb tank. Maybe longer, depends on how you use it.
Keep 2 of them charged and you are good for a very-very long weekend. I didn't find refilling it particularly difficult. Easier than some other trailer chores. - MEXICOWANDERERExplorerI've owned both types of Coleman stove and much prefer the high pressure. Much more heat potential at the burner.
Remember to specifically specify high pressure hose.
I prefer for safety reasons using a 10 lb regulator (they are color coded RED) on the supply line. - SoundGuyExplorer
DavinD wrote:
I just hate to have those throw-away 1lb tanks.
With our previous Spree I plumbed it so I could run not just my 2-burner Coleman stove but also my Weber Q and while it worked fine I tired of setting it up every time and tripping over the hose. I then realized it was the grill that consumes the vast majority of gas, the stove very little, the reason being that a grill needs to not just cook but also preheat but then also burn off residue after grilling. I ditched the hose and began to run the grill with a 5 lb tank and the stove with a 16.4 oz canister. Last year the 5 pounder needed to be recertified so instead turned it in and now run both the grill and stove with canisters. Each spring big box stores around here offer 4-packs of canisters on sale so I buy a couple and find that more than enough for the entire season. This containment box built from scrap plywood ensures the canisters don't roll around in the back of the truck when I'm towing. I can even take along a couple of torch fuel canisters. K.I.S.S. :B
- LwiddisExplorer IIAny bacon left for me, Soundguy?
- DavinDExplorer
SoundGuy wrote:
DavinD wrote:
Sorry, it's a high pressure stove. Most of what I'm reading says that it's better to just tee off one of the tanks as the quick disconnect under the trailer will be too low pressure.
That quick disconnect low pressure feed won't run your high pressure Coleman camp stove at all ... either feed it with a canister or stand alone propane tank or T off one of the trailer tanks before the regulator. If you choose the latter you'll then have a potential tripping hazard in the hose, ergo the reason I just run my own Coleman stove off a canister.
I just hate to have those throw-away 1lb tanks. I know they can be refilled, but it's a pain. I do have the distribution pole that hooks to a big tank that I can put my lantern on, but was looking to use the tanks already in the trailer. I'm just going to Tee off one of the tanks and use a hose. My stove won't be far from the tank, so the tripping hazard is minimal.
I've had my Coleman stove for almost 30 years (my lantern too), I would hate to switch it out for a low pressure one. - AlmotExplorer IIIOutdoor stove can be either high pressure or low.
If you're certain it is high - then what's Soundguy said. Standalone 1lb tank or again standalone 20lb tank.
1lb tank lasts really long time. You can refill it yourself off 20lb tank if you want. - SoundGuyExplorer
- DavinDExplorerSorry, it's a high pressure stove. Most of what I'm reading says that it's better to just tee off one of the tanks as the quick disconnect under the trailer will be too low pressure.
- rrupertExplorerWhat type of stove is it, a high pressure or a low pressure? High pressure takes the 1 pound screw on tanks or a direct connection via hose direct to a bulk tank. The low pressure is made to attach to the trailer's low pressure connection. Give us some info so we can help you.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Jan 18, 2025
