Golden_HVAC
Oct 15, 2015Explorer
7 PSI and the red handle is a great feature. It allows removing the pressure so that the cap can be removed while 'warm', and also prevents the cap from turning while the red handle is down.
You do not want more than 8 PSI. Your older system is designed to run on 6-7 PSI.
Yes you will need a overflow reservoir, and you can find aftermarket ones at any auto parts store, rated to hold the 250F water coming out of the radiator while climbing a mountain grade.
Good luck,
Fred.
Good luck,
Fred.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
