- GordonThreeExplorer
camperpaul wrote:
popeyemth wrote:
GordonThree wrote:
Cut it off with a hacksaw with a stub left and chuck that in a drill.
what option is there if the stabs have neither a bolt head or an allen / hex key hole? on the KZ my stabs have a piece of metal that's been hammered flat on the end, and it fits into a slot cut into the round tube of the jack handle
Good Luck, Mike
Post a photo of the business end of the crank.
this fits over the end of the jack screw, which has been hammered flat to form "ears" which fit in the slot - mlts22Explorer II
martipr wrote:
"Camco 57363 Leveling Scissor Jack Socket" from amazon, $5.14, free shipping if you have prime. Cheaper than buying socket and adapter.
x2. I have multiples of these, and they have worked well for me for years. Easier on the back to just fire up a drill.
I also notice my BAL X-chock wrench fits my stab jacks as well, which has helped me in a pinch. - therebynightfalExplorer.........thanks all for your guidance.
- martiprExplorer"Camco 57363 Leveling Scissor Jack Socket" from amazon, $5.14, free shipping if you have prime. Cheaper than buying socket and adapter.
- Sprink-FitterExplorerI use a 3/4" 1/2" drive socket on a 18 volt dewalt impact driver.
- camperpaulExplorer
Good Luck, Mike
Post a photo of the business end of the crank. - GordonThreeExplorer
Good Luck, Mike
thats what I thought :(
If I come across a 2nd jack handle that's the same, I'll cut one down to chuck in a drill... like having the manual handle just in case. - popeyemthExplorer
Good Luck, Mike - GordonThreeExplorerwhat option is there if the stabs have neither a bolt head or an allen / hex key hole? on the KZ my stabs have a piece of metal that's been hammered flat on the end, and it fits into a slot cut into the round tube of the jack handle
- vic46ExplorerCanadian Tire.The make and model of the jacks may be Googled and you will get the size information you need.
Another choice would be Greg Industries, 5141 - 76A Street Close.
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Jun 17, 2022
