Horizon170's avatar
Horizon170
What size wire.
The distance from my main electrical box to where I want to install a 30 amp receptacle is approximately 30 feet.
What size wire should I pull for my RV plug?
I also have a 27' shore line on the RV that will be plugged into that recep.
Marvin
  • Glad you found it useful. I have used it for a while now and it is one of the better ones I have found. Keep in mind that 8 AWG wire is only rated for 40A so if you want to install a 50A as per a PP, you will need 6AWG.
    SoundGuy wrote:
    kampinguru wrote:
    http://www.paigewire.com/pumpWireCalc.aspx?AspxAutoDetectCookieSupport=1
    Here is a calculator. Says 10AWG
    I've been using this Voltage Drop Calculator for it's simplicity but the Wire Size Calculator you've provided is really user friendly as well ... thanks for the link! :)
  • Yes, the difference in the cost of the wire is negligible, go up one or two sizes.
    I did this last month and going from size 6 to size 4 cable was 2 cents per foot. I had a 100' run, the upgrade cost me $2.00.
    And again, with wire cost being minor, you might even look at going to a 50A outlet in case you ever get a class A. Nothing like having to take out what you already spent good money on to upgrade.
    Bill
  • #10 is required and is perfectly fine. I would use #8 because the marginal cost is small.
  • http://www.paigewire.com/pumpWireCalc.aspx?AspxAutoDetectCookieSupport=1
Having RV issues? Connect with others who have been in your shoes.24,256 PostsLatest Activity: May 22, 2025
