- RycherExplorerjust fyi for all.. i was able to pull it out far enough to see its a geckotech model ecp. very similar to the KIB's on the market..
- mobeewanExplorerMight be able to take the screws out and pull it out far enough to see if there is amfg and moder number. Worse case might need a flashlight and or mirror.
- Dusty_RExplorer
3 tons wrote:
Dusty R wrote:
Not what you are asking, but check out "Sea Level" tank sensors. A much better system given levels in %. And not very hard to install.
Actually, ‘SeeLevel’ by Garnet.
Good catch, thanks. - 3_tonsExplorer III
Actually, ‘SeeLevel’ by Garnet. - Dusty_RExplorerNot what you are asking, but check out "Sea Level" tank sensors. A much better system given levels in %. And not very hard to install.
- Dutch_12078Explorer IIIKIB has made panels similar to that one for many years. If your tanks have the common 4 wire "studs through the tank wall" sensor setup, then it's likely KIB. Here's a link to their current version of that panel:
KIB® - M21 Tank Monitor System Panel - larry_cadExplorer III would take out those two screws, and remove the device so I could look at what is on the back. Probably a manufacturer name and model number.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
